Been working on the 90 Bronco. It has the 5.8 Windsor, I'm trying to get the idle working right, just put some Lucas injecter cleaner in so hopefully that will work. While bleeding the brakes I found a hose sticking out from the gas tank. One end is clipped onto the tank, but the other end is hanging. I'm guessing this is some sort of siphon or bleed of line, but I can't see back far enough on the top side of the tank to see where it needs hooked up. Is this a problem or not that big a deal. Also, the rpm's fluctuate about 150 rpm's with brakes on and in gear. When I'm driving no problem or if the Bronco is in park it's not doing it, only when it's in gear with brakes on. Is that a timing thing or do I need to spend the $80 for a new idle air control? Another problem is the heater. It gets hot but the air doesn't blow out. Is that more likely a switch or the fan motor itself? Is there any way to check one or the other? Thanks
Myke
Myke
