1 - 2 of 2 Posts
currently have a bronco without a bench seat in the front and thought of doing so. is it legal to take 3 people in the front in Australia. better or worse with or without?
Yo Hunterausbronco,
Welcome to our Big Bronco Family!
Mount Info; "...The Broncos come equipped with both mounting capabilities, Bench and buckets. I just did this very swap from buckets to bench out of a 93 F150 XLT at the junk yard, it came with power dual lumbar, fold down arm rest, and dual cup holders for $45.00 in new condition. The mounting points for the bench are there under the carpet and they are plugged with rubber grommets. You do not have to tapped the holes either, the bolts that hold the buckets in place are self tapping, and they go in rather easy. The mounting points are made up of metal sleeves that are not threaded if never used and the self tapping bolts are easy to install. Just swap over the rubber plugs from the bench locations to the bucket locations and you are set.
173742
173744
(Diagrams by Ford via Steve)
You also use the same seat belt locations and you are going to have to use the seat belts from the bench. The belt plastic sleeves are molded differently, and will not point in the right direction. Everything is plug and play, down to the lumbar..."
by Camo Horse (g8rfan, Bill) at FSB
I believe some 82 or 83 Broncos have 50/50 split bench seat and seatbelts for 3.
173746
Pic from 1982 Bronco Sales Brochure (see it below)
Inspect floor pan for rust, etc.
Here is some other info for you;
1982 Ford Bronco Sales Brochure by Ford via https://www.broncocorral.com/resources/1982_ford_bronco_brochure.pdf
EEC III Testing, Pin-Outs, Wiring & Vacuum Diagrams in an 82 by Tommy
DIY EEC III Timing Procedure by Eric, DONOTDELETE @ EEC III - Off-Road Forums & Discussion Groups
1982 Bronco "What's New for 1982" Brochure by Gary
1982 Light Truck Facts Book by Gary
1982 Bronco, F & E Series Accessories Brochure by Gary
1982 Bronco Advertisement "A lion in winter!"
1982 Fastener Pictures & Illustrations by Gary
1980-1986 Bronco/F Series Carburetors, Chokes & EFI by Gary
1980-1986 Bronco/F Series Specifications by Gary @ Axle Ratios - Gary's Garagemahal (the Bullnose bible)
Differences in 1980-1986 Bronco/F Series by Gary
Haynes Red Manual for 80-95 Bronco & F Series @ Hanes guide 80-96 bko f series.pdf via BroncMom
For any Bronco questions or to chat about it's planned modifications or build, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories that requires 50 non- padded posts to buy or sell due to scammers who preyed on our members.
Please fill out your Bronco Info with year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc. for better responses.
How To Add Your Signature »
From the navigation, near the upper right-hand corner, click on your avatar and then select “Account Settings” from the drop down menu.
From your “Account Settings” page you will then see more navigation option of the left side. Select “Signature”.
Now you can simply enter your signature information in the text editor and click save.
Our site FAQs includes for example: How to Use Search, How to Post Pics to posts and more tips.
➡ See Baba Looey's Favorite FSB Links (lots and lots of tech links), including, "how do I get the tailgate glass to...", etc.
Please take time to Participate & VOTE in our Full-Size of the Month Contest & later in the year, Full-Size of the Year Contest @ F.O.T.M Voting
You will get ideas by those competing.
Prizes are awarded! A full spread in Bronco Driver Magazine is the top prize, in addition to a years subscription, once the article is submitted. Also, a years worth of premium FSB membership is awarded to the winner!
Al
1 - 2 of 2 Posts
