1 - 3 of 3 Posts
alright used the see clamp to push the piston in and now i suppose to nock the caliper pins inward to remove caliper but i don't see the pins.i have a 1994 bronco
Master Bater
yes, you have the two bolts in the back, IIRC they are 9/16. just unbolt them and shimmy the caliper off the knuckle/backing plate. You really only need to use the c clamp to push the piston back when you are getting ready to remount the caliper, as newer pads are obviously thicker than the old. it should come off pretty easliy
1 - 3 of 3 Posts
