1 - 4 of 4 Posts
1988 Ford Bronco XLT
I need to change my front brakes on my 88 and I have never seen so many options for rotors for any truck and I really don’t know what I need, my bronco is a 1988 with manual locking hubs, any help will be greatly appreciated!
The biggest thing you'll need to find out is if you have the external locking hubs that were only used in '87 and part of '88 and the normal "internal" hubs that Ford (and everyone else) has used since the 70s. I think the brake components (rotors at least) are different between the two. Do your hubs fit into the hole in the end of the spindle? Then they are internal hubs. Does the locking hub just sort of slide off the spindle when the wheel is off? Then you have external hubs. Once you have that figured out, you can order the right parts.
Moderator and Scrounger Extraordinaire
You will commonly find the 87 and early 88 lockouts referred to as Top Hat Hubs. They are much simpler to do the brakes on, as the wheel bearing races come pressed into the rotor already.
Ive been using Advance Auto's Wearever Silver brakes for years with good results on trucks and a mustang
You dont need drilled and slotted or any other fancy rotor or pads.
1 - 4 of 4 Posts
