1 - 3 of 3 Posts
So after finishing the front 5.5" lift on my 92 bronco, I look at the superlift extended brake lines that seem to just dangle. What do you all suggest to secure them so they don't rub on the tire or get pinched in the spring without taking away from the length required under full articulation? Thanks
I plan to just be careful with the routing. anything you do tie them to something that isnt thought through could cause you snatch it apart. then you have created the problem you hoped to solve.
1 - 3 of 3 Posts
