Just lookin' for possible ideas on how to mount some front recovery points on my pickup. I would mount them in front of the crumble zone, but when they previous owner installed a body lift, he cut the front of the frame horns because they got in the way of the bumper, when it was relocated higher up. I really don't like the idea of havin' them just welded on. I always feel safer with some grade 8 bolts holding recovery points on. Any ideas on how, and where, to mount them?
Best picture I have showing where my front frame horns are cut.
Discussion Starter #2
I'm thinking of doin' somethin' like this. Welding a piece of plate, or angle to the according part of the frame, then laying a piece of plate on the inside of the frame when bolting it down. To give it a flat point to press against, sandwiching the accordion part of the frame. Thoughts?
LOG TRUCKIN'
There's no more pics in that link. With out pics, it's just a little bit useless. :doh:
Banned
...he cut the front of the frame horns...
Technically, the frame is ruined - Ford recommends NOT trying to repair the crumple zones. But since you're not going to change the frame, your options are fairly wide-open.
It's certainly easier to get a good bolted joint than a good weld, and a damaged bolt is far easier to identify & repair. I'd weld in a repair piece to replace whatever was cut away, and then bolt some stock eyes to that. These are the type I prefer because they're common, sturdy, versatile, and available in either cast iron or Aluminum.
But there are MANY styles available:
LOG TRUCKIN'
Recovery Hooks
Just got these today from the JY. Best I could find there. No late model Fords. Pulled em off a chevy. I'm gonna start working on mounting them tomorrow. Will be taking some pics of what I figure out for them.
:armed
yo,
Installation in 92-96 w/PICs (including toolist & wrnech pics, and bumper cut-out drilling angles!!)
Source: by Froggmann (Ken P) at http://www.thewebwheeler.com/forums/showthread.php?t=2023
Source: by Tony R (TonyR) at http://fullsizebronco.com/forum/showthread.php?t=129200
Source: by Scott F at http://www.off-road.com/trucks-4x4/tech/recovery-points-for-big-broncos-18389.html
more LINKs in my site @ http://www.broncolinks.com/index.php?index=328
