I need your opinions on the wheel wobble up front. I've got my tires rotated and balanced, went to another tire store and they did an alignment, but said that my alignment was already perfect so I didn't need one, they also re-checked my front right (passenger side) tire and said it was balanced correctly. I switched my driver side rear shock with the front ride to see if it could be the shock and it still wobbles. I have a new (fairly new) inner tie rod. I'm thinking it could be either a bad coil, bad outer tie rod ends or maybe even a bent or cracked frame somehow. Anyone have any ideas. Thanks for any and all suggestions.
