This no start has me pulling my hair out. I've pulled a plug and have good spark. Checked the distributor and it didnt move. Have 40 psi at the fuel rail with a new fuel pump. Noid lights flash when cranking over.Cranks over fine. But nothing, not even a sputter.
About a year ago I woke up and the truck wouldnt start. A few months later I went to work on it, and it started right up and ran fine, but 10 min later when I tried to start it again, it wouldn't start. A few months later, same deal. Now I'm getting nothing.
Any ideas what else to try? Is there a way to check the injectors are actually spitting fuel?
As a quick check since you have fuel, spark and the injectors are being commanded to fire put a timming light and check while cranking. Could be ignition system related.
I had a similar issue with my 93 it turned out the map sensor was bad I had fuel press and spark but the computer wouldn't fire the injectors
Check your Catalytic Convertor.
If it's factory, they have a tendency with age to plug up inside and keep the engine from starting, period. Went thru this at 75,000 miles w/ 351W and best professional guesstimate was a slipped timing chain. NOT!
Once exhaust manifolds were unbolted to breathe freely, it started right up and sounded like a race car.
Best scenerio, if you don't have to pass smog tests to register, punch the guts out of the convertor or take it off completely.
Roller rockers are gay
Your case is the first I've heard of where a bad converter wouldn't even let the engine start. Cats don't go bad from sitting.
I'm betting on an ignition or sensor related issue. Pull codes dude.
