1 - 10 of 10 Posts
Resident Wrecker Driver
:banghead I just replaced the fuel pump, tank, sending unit and straps on my 1990 302. The fuel guage is going crazy now, it jumps from empty fo full. I only put 4 gallons of gas in it. WHAT THE HELL, I JUST WORKED IN THE RAIN TO GET IT TO RUN TODAY AND NOW THIS!!!!??? :banghead
green ones make me horny
check your gorunds.
Call Me Ace
you replaced the in-tank fuel pump? are you sure you hooked up the wires to the sending unit firmly?
mine did the same thing when the sending unit was going bad...
ace
Rest in Peace Friend...
Since you just replaced the sender, it sounds like a connection problem.
search, you #$%@! noob
same exact thing happened to me.
i replaced the sending unit- twice. still, whenever the tank was below 1/4, the gauge would bounce all over the place like that. above 1/4 it worked fine.
i just kept the tank above 1/4 and lived with it...
Mine does the same. The first went bad when it became cold in the winter. The second worked fine until the winter and then went bad.
It could be a bad connection somewhere. The pump and sender wires go through the connectors on the DS inner fender. They are in different connectors so it may pay to clean them all up.
The Ford dealer replaced my sending unit and pump, then the gauge became erratic. This went on for about a week then stopped and has been normal for about a year. I'd give it some time before I took it apart.
my gas gauge jumps around after changing the gas tank on my 90 with a 351 and i checked the plug on the tank and it seams to be tightdoes any one know what wires are what i have a black witch i asume is the ground and i also have a red,orange and a yellow wire and cant find the wiring diagram in the book
Who needs oil anyways....
Black would be a fuel tank ground and yellow is the sender signal. My plug only has three and the other is red, powering the low pressure fuel pump.
1 - 10 of 10 Posts
