1 - 4 of 4 Posts
Good fuel seending unit by the book.Proper ohms reading.Fuel guage good!!Seperated fuel guage from printed circuit.Wired guage with own power from ign.Then to sending unit !! It works!!Vary strange.Could it be voltage regulator for printed circuit?? Fuel guage is last in line for power on printed circuit:banghead !!.
Discussion Starter #2
Backwards reading fuel guage!!!
]Good fuel seending unit by the book.Proper ohms reading.Fuel guage good!!Seperated fuel guage from printed circuit.Wired guage with own power from ign.Then to sending unit !! It works!!Vary strange.Could it be voltage regulator for printed circuit?? Fuel guage is last in line for power on printed circuit:banghead !!.
Never ending project
Did you change your float and sending unit recently if its not the right one it could make it read backwards.
Banned
1) Add some specifics about your truck to your profile so we know what you're working on.
2) If your cluster has a voltage regulator, DON'T wire any of your gauges with direct 12V - you'll burn them or the senders up.
3) If the gauge moves opposite of the float, you've mixed years with the gauge & sender. Pre-'87 is different from later years, so you can't cross that line.
1 - 4 of 4 Posts
