1 - 8 of 8 Posts
so after starting my car today i noticed there was a fast ticking noise coming from the engine, when i poked the stethoscope around i noticed the noise was coming a driver side fuel injector. the car is a v8 351w 95 bronco. is this fixable by rebuilding all injectors?
Are you sure it is an injector you're hearing?
Your '95 is batch fire, which means four of the injectors are pulsed at the same time.
I'd bet that it is a tappet that's making the noise, try listening to the tappets. You could also unplug the one injector that seems to be making the tapping noise. The fact that an injector is clicking, usually isn't a problem, and injectors are usually not loud enough to hear them.
Good Luck!
Injectors can indeed tick, they can get sticky inside and make it worse. I know a source that can clean and rebuilt them all for $40-$50. PM me if you want his contact information
Not true. Almost all '95s with E4OD/4R70W (regardless of destination) were MAF SEFI. According to the Ford EVTM, they ALL are, but I've seen a few around here that aren't.
http://www.supermotors.net/registry/media/994159
This holds true for the 5.0's. Everywhere I've read, states that the 1995 model year-5.8 Bronco's are SD except California models which are MAF. All 1996's models were MAF including the ones built in 1995. Maybe that's where the mix up is, the build date :shrug
Here's a '94 MAF 5.0L 4R70W F150 originally delivered to Memphis (DSO 23):
http://www.supermotors.net/registry/media/319488
http://www.supermotors.net/registry/media/319485
This doesn't pertain as it's a 5.slow. :twak
Steve, fast forward to 3:55 for the VECI Label. This is a California '95 with the 5.8. I can make out where it says "California Regulations"
OK :thumbup Now we need all the details of those trucks to find out if the '95 5.8L CA package always includes SEFI MAF, or if it's only on E4OD trucks. :shrug And I need to watch for '95 5.8L trucks around here to find out if any are non-CA MAF/SEFI.
Gawlf - can you post a clearer pic so we can read the calibrations? And then fill in all the details in your signature? Read each of these:
http://www.supermotors.net/registry/media/858380
http://www.supermotors.net/registry/media/72354
Yeah, will do. give me a couple days though - Im having a busy weekend - but will get a better photo as soon as I get a chance.
1 - 8 of 8 Posts
