For some reason, my fuel wont reach the engine... it leaves the tank but doesnt leak out...
Engine starts up and runs for a few seconds when I pour fuel into the carb.
To me, it maybe sounds like a reall clogged fuel filter, but I dont know where that is to check, as I am a noob to working on cars.... any ideas?
Your fuel filter should be in your driver side frame rail and ther should also be one in between the carb and the manual fuel pump on the lower side of the engine
my bko ate my money
"Engine starts up and runs for a few seconds when I pour fuel into the carb."
:toothless
:doh0715: brain fart
could be a clogged filter( on frame or in between fuel pump & carb) or just a fuel pump failure, you got the easy manual FP on the side of the timing cover, your filters should be easy to check also
