My fuel pressure reads 35psi when it is running and when I shut off the fuel pressure slowly climbs to 39psi after 15 minutes its starts to go down. After a ½ an hour or so it about 5psi is this normal. I ask because sometimes when I shut it off and go in the beer store and try to start again I have to crank it for like 5 to 10 seconds till it starts. And when it starts I can smell fuel. I put on a new fuel pressure regulator and it does the same thing (I put the original back on) In December I put in a new fuel pump after it went bad. It seam to me it stated to do this when after I changed the fuel pump. I got the fuel pump from my local ford dealership.
I’m going to try changing the fuel filter to see if anything changes. Or maybe I should stop going to the beer store. Thanks for your help
James
James
