1 - 2 of 2 Posts
bronco will start eventually with starter fluid and will idle normal but when i give it any gas it dies... i put two new pump relays and a fuel filter on it... according to my book it has a pump on the frame (high pressure) and one in the tank (low pressure)... the one on the frame is 100 bucks roughly and the one in the tank is around 50... i really would like to get it going w/o having to get both pumps so if anyone has been through this and has a good idea which pump it would most likely be i would appreciate the input greatly.
thanks in advance,
brian
Do you have a fuel pressure gauge? They make some that connect to the schrader valve on the fuel line so you should be able to tell if you have a dead pump.
1 - 2 of 2 Posts
