Did you check the line from pump to carb? If it is rubber hose it could be collapsed internally. I am presuming you did not pull the pump to carb line off and try cranking it over to see if the pump is actually pumping fuel if you tore the front end apart. If not how did you verify the fuel pump was getting gas?
Oh and I just noticed you only have 1 post but are a FSB member. Thanks for supporting FSB.
