today i was driving down the interstate, i stopped cause of traffic and it died.
so i checked the fuses and the fuel pump fuse was blown.
it had done that about a week earlier and i put a new fuse and it was fine
now it keeps blowing the fuse after the pump primes. i found that the red wire to the pcm relay and the yellow wire from the relay to the fuel pump fuse are shorting somewhere. could the pcm be bad?
How are the ground contacts?
the only ones i saw were on the fender iroc. ill check and clean those tomorrow. are there any others i should look at?
Follow wire bundle back to rear tank and make sure there are no open areas where it could short out on the frame....
yo,
Ground Location in 92-96; "... pump and fuel level sender share a ground) At Rear cross member..."
Source: by miesk5
Check the connector on top of tank; could be damaged/deteriorated due to water/moisture/sludge
update
well since it stopped raining i got to get under the bronco and look for the short. the red fuel pump wire was shorting against the frame in front of the t case. i fixed it and it worked fine, thanks for the help:thumbup
