1 - 12 of 12 Posts
Mechanically challenged Bronco onwner needs help. I had to replace the fuel pump on my 1983 351 Windsor Bronc today. After finally getting to the old one and getting it off I got the new one installed, but obviously not correctly, as it is not pumping any fuel. I have done the output test per the Haynes manual by having the lines go directly from a gas tank and into another contanier and then turning the ignition, and there is no gas being pumped.
Someone said I should have seen a "pin" when I removed the old pump, but I did not see anything. Is there a certain way the pump has to go in? I tried looking into the space where the pump goes and I don't see anything that would push the lever down on the pump to make it work? What am I missing, besides some mechanical skills. Any help would be greatly appreciated.
I have the line that would normally go to the gas tank going straight to a full gas can, and the line that connects to the fuel filter going to anohter can just to test and make sure the pump is actually working, and I have not gotten any fuel at all. The lines are totally dry. I have tried it for 10 sec each time, but only 2 times. It was kinda hard to pull the old pump out, but it wasn't real hard to get the new pump back in.
Should I just crank on it longer and see what happens? Is it possible to put the pump in wrong if you have it bolted in?
Yes you are correct it does have a lever not a rod, I was replying to the other post.
The rotor is turning, actually it will fire up fine if I spray a little starting fluid in the carb, it is just a problem with the pump. It is not pumping any fuel, so it is a big problem. Is it possible to put it in wrong? Like I said I did only crank it for about 20 sec total with the new pump, is that not enough time to get it going? Thanks again for your help.
green ones make me horny
what rid are you all talking about with the fuel pump? im lost here, i did a buds 150 and there was nothing driving it. it is electric
I got it running on carb spray and there was very little if any suction, any other suggestions other than bad pump. If there were any other engine problems would I be able to get it running on carb spray, I mean if I had a blown engine it would not even fire up on carb spray correct? Sorry for all the stupid questions like I said I am learning as I go. Thanks again.
Discussion Starter #11
1983 Bronco 351 Windsor Carb it is not an electric pump it is mechanical with a rocker/arm. The arm is about 6 inches long or so.
oh okay gotcha. im thinking fuel injected
1 - 12 of 12 Posts
