1 - 3 of 3 Posts
If a mechanical fuel pump was starting to go bad and under load didnt deliver enough, fuel subsequently leaning the mixture out preignition would follow,yes?If so could it be possible that only 2 of 8 plugs show preignition while the other 6 look god leaning to leaned out (hot)
A mechanical fuel pump is one that does not have electrical power. I had an in tank pump that was going out, it would die and not start when hot. Sounds more like you have a major vacuum leak.
Whether the pump is mechanical or electric if it cannot supply enough fuel, with the resulting loss of pressure, it will cause a lean condition. Yes it is possible to have only 2 plugs showing signs of detonation. Uneven cooling and fuel/air distribution between cylinders is a real world issue in all stock engines. Some worse than others.
1 - 3 of 3 Posts
