Yo Bill,
as for "Now, my fuel gauge bounces around a bit between empty and ¼ full"; is this while travelling down da road? if so, figure on at rest a gauge reading that doesn't move indicates an open circuit (blown fuse; corroded terminal) on the power (battery) side of the gauge OR a bad instrument cluster ground at C251 pin 9.
The terminals of C251 (& C250) are known to corrode & lose contact. Polish both the connector pins AND the film circuit pads with brown paper or a pink eraser. The larger version of C441(WPT454) was used until '93. The level sender can usually be disassembled & repaired by bending the wiper arm inside the plastic housing to apply slightly more force..."by Steve83 (Steve, That dirty old truck) at http://www.supermotors.net/registry/media/744437
See his diagram and read more.
Sender Range: 160 (full) - 16 (empty) Ohms
