1 - 3 of 3 Posts
What do you guys think of this fuel sending unit i found on ebay?
I will be getting the 33 gal gas tank from Rock Auto (LILAND GLOBAL IF8A {#D8TZ9002B} Lock Ring Kit Included 33 Gal.)
I won't be getting the sending unit from there since it cost about $189.
Is there something better or am i going in the right direction with this.
Bronco doesn't have any mods or anything special to it yet.
Thank you and you guys have a great day!
Yo Danycacks,
Welcome!
The sending unit appears to have good reviews as does LILAND GLOBAL.
Tank Hanger Fabrication Info & pic & Painting in a 79
Source: by nunrush @ https://www.supermotors.net/registry/20682/70907-2
Skid Plate & Pads; "...If the pads are beyond re-use, I recommend camper shell mounting tape because it's a closed-cell foam intended for heavy loads with slight movement in an automotive environment..." by Steve
Assuming you have a 78:
1978 Bronco Dealer Brochure via Indybronco
1978 Bronco Emission Component Location Diagrams via 78brncoxlt
1978 Ford Bronco & Truck Wiring Diagrams by Ford via Bronc Mom @ https://drive.google.com/file/d/15KEp-dmAewg_76EfeIPysZGftmGiO7fN/view
1979 Bronco/F Series Electrical & Vacuum Troubleshooting Manual via topsig (Ziggy); similar to 78.
1979 Wiring Schematics, Connector Pin-outs, etc by Ranger429 @ https://www.fullsizebronco.com/forum/6-1978-79-bronco-tech/223050-79-wiring-schematics.html
Similar to 78
Bubba's M-Block Ford V8 Workshop by Dave Resch @ Bubba's M-Block Ford V8 Workshop
MANY 78 Parts Break-Out Diagrams by Indybronco (Lula Mae) @ pictures, videos, and sounds | SuperMotors.net
78 351M/400 Engine Exhaust Emission Control Information Decal & Timing by member grovermyson @ https://www.fullsizebronco.com/forum/6-1978-79-bronco-tech/505882-timing-do-i-need-do-anything.html
C6 Auto Transmission, if equipped, Description & Operation, Adjustments, Diagnosis & Testing (partial), Disassembly & Assembly, Parts Break-Out Diagram, Hydraulic Control System Diagram, Removal & Installation & Specifications @ https://redirect.viglink.com/?format=go&jsonp=vglnk_155464716156516&key=6ed47b392b9edfe394b9e89b72717104&libId=ju70qeuf01000bgv000MAb4isjltc&loc=https://www.fullsizebronco.com/forum/6-1978-79-bronco-tech/210246-c6-rebuild.html&v=1&opt=true&out=http://www.thedieselfiles.com/Ford/C6%20Automatic%20tranny.pdf&ref=https://www.google.com/&title=C6 Rebuild - Ford Bronco Forum&txt=Description & Operation, Adjustments, Diagnosis & Testing (partial), Disassembly & Assembly, Parts Break-Out Diag...
Partial Chilton Manual for 1978, 1979, 1980, 1981 Bronco. Scanned by broncocity.com @ https://web.archive.org/web/20130419152159/http://www.broncocity.com/66-81manual.htm
Ford Shop Manual Diagrams: 1978-1979 Full Size Shop Manuals, partial @ https://broncograveyard.com/rt-1273-technical-diagrams-archives.html
My Tablet takes too long to download, so try the first in this list as long as you have Adobe Acrobat 9 installed. Let me know if the downloads are worth the effort, you'd be the first of many to do so.
Includes:
Wiring Manuals & Diagrams Download PDF
This complete manual for the 1972-1979 Ford Bronco Includes Rear Lights Diagram
Motor Manuals & Diagrams Download PDF
This complete manual for the 1972-1979 Ford Bronco Includes Air Cleaner Diagram
Chassis Manuals & Diagrams Download PDF
This complete manual for the 1972-1979 Ford Bronco Includes '78 Brakes Diagram, Gas Tank Setup Diagram
Body Manuals & Diagrams Download PDF This complete manual for the 1972-1979 Ford Bronco Includes; Upper Body Diagram, Front Clip Diagram, heater Ducts Diagram, Tailgate Diagram, Console Diagram, Front Clip Diagram, Grill Setup Diagram, Heater Controls Diagram, Interior Trip Diagram, Rear Sheetmetal Diagram, Tilt wheel Diagram, Tire Rack.
Order a Ford authorized repair manual other than the EVTM, either a Bishko or a Dave Graham from rockauto.com in Literature section or other source. If it's a CD, ask if it will run on your device.
For any Bronco issues or to chat about it's planned modifications or build, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Build section that requires a 30 post count & Bronco and Ford Parts/Accessories (75 posts required to view).
To save you time and for better responses, please fill out your Signature with location, year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc. .
From the navigation, near the upper right-hand corner, click on your avatar and then select “Account Settings” from the drop down menu.
From your “Account Settings” page you will then see more navigation option of the left side. Select “Signature”.
Now you can simply enter your signature information in the text editor and click save.
Our Forum faqs @ https://www.fullsizebronco.com/help/faq/
Includes for example:
How To Upload Images To Posts & How to Use Search
See more tips!
Baba Looey's Favorite FSB Links (lots and lots of tech links) @ https://www.fullsizebronco.com/forum...ech-links.html
Look at some Technical Service Bulletins @ http://www.bbbind.com/tsb-wiring-diagrams-database/
Try to find time to Participate and VOTE in our Full-Size of the Month (F.O.T.M.) & Full-Size of the Year (F.O.T.Y.) Contests @ https://www.fullsizebronco.com/forum/27-f-o-t-m-voting/
Contests will be held in JANUARY, MARCH, MAY, JULY, & SEPTEMBER. Each month in-between will be used for nominating contestants to run in the following Month.
Then get ready for the Full-Size of the Year (F.O.T.Y.)!
Al
1 - 3 of 3 Posts
