Fuel supply manifold
292 Views 2 Replies 2 Participants Last post by  gaabyyj
Hey everyone reaching out for some help with my bronco ii 1988. Was replacing the fuel injectors and noticed the fuel rail (fuel supply manifold) is pretty much shot. The entry points for the injectors are a bit damaged from debris. Has anyone ever come across this issue? Trying to salvage the part. I can’t find a new or used one.
1 - 3 of 3 Posts
Are they damaged where the o-ring sits? If the sealing area is good, just knock down the rough area with a Dremel wire wheel or equivalent so the new o-rings don’t tear when you push them into the fuel rail.
If they weren’t leaking when removed then chances are decent the sewing surfaces are good enough for reuse. I cleaned mine up with some WD-40 sprayed on a buffing wheel tool using my Dremel.
Thank you for replying brother!!!
1 - 3 of 3 Posts
