Just signed up for the Site and this Bronco is New to me.
Not sure where to start so here we go. 1990 Bronco with 302 and A/T in it. I bought it not running (for $800)and the guy said the fuel system had an issue. So I got it home and the wife started to diagnose the electrical portion. At the Fuel pump relay it was low on one of the readings. So we went ahead and tried to check the pump. Pump didn't come on. But when we ran power straight to it, it came on. It did die shortly after though. So bought a new pump and put it in. Turn truck to run and nothing so we ran the hot wire again. Pump kicked on but nothing happened. So I blew air into the line at the filter (on the frame) going back to the tank and it started working. Checked pressure on the Fuel rail and Nothing there. Bone dry. Blew air into the valve and heard gas come back into the tank. Turned on the pump and still nothin on the fuel rail. Not sure where the clog is at or how to figure it out. Any ideas? What is the silver box on the fuel rail that has a vaccuum ine going into the top of it. I am worried that the injectors will be clogged since the tank was so contaminated. Took a few hours to clean out the tank from all the garbage in it
