1 - 8 of 8 Posts
I have a 79 bronco that I'm swapping the 25.5 gal tank to a 33 gal plastic tank. The 25 gal tank has a factory skid plate. My question is, will the current skid plate work with a 33 gal tank, and will I have to replace the upper straps. Any help would be appreciated.
Yo 7,
Welcome!
You may see some answers to your questions in
Installation pics, 33 gallon in a 79
Source: by FordTruckBroncoMan (Big Red, FordTruc
Supermotors is back up⚠
Same for:
Size Differences, 25 vs. 35 gallon pic in a 78
Source: by Jason R (baby ruth)
Installation, Polyethylene; "...I absolutely hated the poly tank I had to put in the '75; especially those scraps of bent GARBAGE that hold the sender plate in..."
Source: by Steve
Polyurethane Differences info in 78-79
Source: by Kevin M (Project Double Agent)
About this capture
My Bronco came with the 33 gallon gas tank. The only other option for 78 and 79 Bronco's was the 25 gallon tank. If you are lucky enough to have the 33 gallon tank, then you also have the factory skid plate. The 25 gallon tank did not come with a skid plate, it uses two straps to support it.
I decided to replace my old metal tank with a polyurethane tank. There was some corrosion on the bottom of my old tank, and it was just a matter of time before it would have started leaking. This is a very easy swap to do, and well worth the $110 cost. There is no more corrosion to worry about and the polyurethane is much more durable than metal.
There are a few things to note before you make the swap. The tanks are available for 78's and 79's in both sizes. The 33 gallon tanks are the same except for two things. 79 tanks have an emissions hole on the top which connects to a line that runs up to the engine compartment and connects to the charcoal canister. 78 model tanks do not have this hole. So if emissions laws in your area require this, make sure you get the right one. If you get the tank with no hole, you will need a vented gas cap to relieve pressure in the tank. The other issue is the vent hose port. If you have a 78 the vent port is left of the filler hole, and just the opposite on the 79 models. Not a major issue but would require some modification to make it work if interchanged."
Click on the pics for a larger version.​
Here is some info for you;
Ford 1979 Bronco/F Series Electrical & Vacuum Troubleshooting Manual via Ziggy⚠⚠⚠ @
1979 Ford Bronco Wiring Manual pictures, videos, and sounds | SuperMotors.net
It shows Electrical component location, operation, troubleshooting, with wiring and vacuum diagrams.
1979 Ford Bronco Wiring Schematics, Connector Pin-outs, etc by Ranger429 @ https://www.fullsizebronco.com/forum/6-1978-79-bronco-tech/223050-79-wiring-schematics.html
1979 Bronco Brochure (partial) @ http://broncohq.com/Broncosales/79/79salesinfo.html
1979 Ford Bronco vs. Blazer Article by Ford via Indybronco @ 1978 Ford Bronco Bronco vs. Blazer (79) pictures, videos, and sounds | SuperMotors.net
See Technical Service Bulletins @ BBB Industries- Premium Alternators, Starters, Power Steering Products and Turbochargers | TSB and Wiring Diagrams Database
Ford Shop Manual Diagrams: 1978-1979 Full Size Shop Manuals, partial @ https://broncograveyard.com/rt-1273-...-archives.html
My Tablet takes hours to download, so try the first in this list as long as you have Adobe Acrobat 9 or later installed.
Includes:
Wiring Manuals & Diagrams Download PDF
This complete manual for the 1972-1979 Ford Bronco Includes Rear Lights Diagram
Motor Manuals & Diagrams Download PDF
This complete manual for the 1972-1979 Ford Bronco Includes Air Cleaner Diagram
Chassis Manuals & Diagrams Download PDF
This complete manual for the 1972-1979 Ford Bronco Includes '78 Brakes Diagram, Gas Tank Setup Diagram
Body Manuals & Diagrams Download PDF This complete manual for the 1972-1979 Ford Bronco Includes; Upper Body Diagram, Front Clip Diagram, heater Ducts Diagram, Tailgate Diagram, Console Diagram, Front Clip Diagram, Grill Setup Diagram, Heater Controls Diagram, Interior Trip Diagram, Rear Sheetmetal Diagram, Tiltwheel Diagram, Tire Rack
Let me know if the downloads are worth the effort.
See Bubba's M-Block Ford V8 Workshop by Dave Resch @ Bubba's M-Block Ford V8 Workshop
Partial Chilton Manual for 1978, 1979, 1980, 1981 Bronco. Scanned by broncocity.com @ https://web.archive.org/web/20130419152159/http://www.broncocity.com/66-81manual.htm
Dave Graham's 1979 Ford Truck Manual on CD @ https://www.rockauto.com/en/catalog/...r+manual,10335
Authorized copy of the Ford manual for all systems. Ask seller if it will run on your PC, etc. with it's operating system such as WIN10. Three Volumes!
Search Google for a better deal.
Please fill in your Bronco info;
From the navigation, near the upper right-hand corner, click on your avatar and then select “Account Settings” from the drop down menu.
From your “Account Settings” page you will then see more navigation option of the left side. Select “Signature”.
Now you can simply enter your signature information in the text editor and click save.
➡For any Bronco questions or to chat about it's planned build, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as 1978-'79 Bronco Tech that requires 30 posts to view or post or add more posts) or 1978-'79 Bronco Tech, Bronco and Ford Parts/Accessories (75 posts required to view), etc.
I'll move this thread to tge Noobie section to gsther more attention.
Forum FAQs @ https://www.fullsizebronco.com/forum...lies-faqs.html includes for example:
Baba Looeys favorite FSB Links, lots & lots of tech-links @
https://www.fullsizebronco.com/forum...ech-links.html
How to Post Pics @ https://www.fullsizebronco.com/forum...-pictures.html
How to search @ https://www.fullsizebronco.com/forum...-advanced.html
➡ Try to find time to participate in and Vote in our Full-Size of the Month (F.O.T.M.) & Full-Size of the Year (F.O.T.Y.) Contests.
Contests will be held in JANUARY, MARCH, MAY, JULY & SEPTEMBER. Each month in-between will be used for nominating contestants to run in the following Month.
You will get ideas by those competing. Also see the prizes! They are awesome as compared to other sites' "contests"!
Then get ready for the Full-Size of the Year (F.O.T.Y.)!
Enjoy!
Al
I've just went through the same thing, exactly. There is a separate post or a post in my build page that explains what I did with pics and etc..
Basically, I bought some different length bolts (4" and 6" I think) to replace the stock strap bolts and hold the bigger tank. But keep in mind this is only temporary solution for me as I have a parts truck 33 gal skid plate coming along sometime soonish. I've been running around semi DDing it like that for months, but no trail stuff.
Besides the old rusty bolts (I hosed them down 2 times a day with pb blaster for a week), the worst part was getting the filler tube situated on the fuel door end.
hope this helps, if you cant find my refs, let me know and I'll dig them up if needed.
Yo 7,
Welcome!
You may see some andsers to your questions in
Source: by FordTruckBroncoMan (Big Red, FordTruckMan)
However Supermotors is currently down.
Same for:
Source: by Steve
Thanks for the information. I just want to make sure I know what I'm getting into before I start.
Yo 7,
Good thing to do!
Hope the Supermotors admin will get it running again.
Be well!
Great info and the pics helped. I'll let you know how it turns out.
1 - 8 of 8 Posts
