In Front of Jopes
How do I make sure it's only the fuel tank leaking not a line?
The bottom of the tank and skidplate has a visual fuel stain, but there is an small stain on one upper portion of the tank, not sure if it's fuel.
Are the fuel tanks from JBG good as OEM which are 450ish?
Rest in Peace Friend...
Sure sounds like a fuel leak to me. 450ish for an OEM tank??? JBG sells quality stuff. I got mine from 1Aauto http://www.1aauto.com and then undercoated it. You will most likely want to replace the skid plate and insulating strips also. If the tank is rusted the skidplate probably will be too.
good luck,
:thumbup
