1 - 4 of 4 Posts
Screw the Jeep Thing
Is there a special tool to take the wires out of the back of a the EFI Fuse/RElay box? I'm thinking of using that instead of having a bunch of relays and stuff all over my truck. But wnat to use a whole new set of wires.
Cool Thanks.
AKA: Butthead
I use a 2mm & 1.5mm wide screwdrivers, most of the Ford stuff can be
disassembled with those
http://fordfuelinjection.com/index.php?p=74
x2 :)
And to get the typical wire connections unplugged I've found a cotter pin
puller to work great. :) Do yourself a favor and get one of these things...
http://www.panix.com/~alvinj/file12/cotterpin.jpg
...I use it for everything except pulling cotter pins.
For cotter pins I use "line pliers". ;)
My first cotter-pin-puller was found on the side of the road and had been
run over. Used it to yank a body-shim back-out (it was going crooked)
the other day, the hole they put in those shims sure came in handy. ;)
For the last few months have been using it to operate the ignition switch
that's hanging underneath the dash of my '91.
If you really want to get into this, another handy tool (sometimes needs
modifying) are "street sweeper broom straws".
Alvin in AZ
1 - 4 of 4 Posts
