Just to answer a few questions for you guys... I ordered the NEW (not an old case that's been rewound) from PA Performance for $185.00 and I got the 4 gauge power cable from them for I think $30.00. (Big Fuse included). Actually PA Performance suggests very strongly that you get the big cable, if you don't and you run the alt hard, it WILL burn stock wires. I ordered the unit through PEP BOYS, but I was the one who talked to the guys at PA on the phone when I ordered it. They treated me real nice on the phone, asked me what it was for, what system I had, how many lights and what kind, and told me my options, no pushing at all, and in my opinion that counts for alot. At the time I didn't have a lot of excess scratch so I got the plain case unit. But instead of a straight replacement I bumped up to the 135 amper.
PA Performance sent me this alternator and it was GORGEOUS. The case had no burs, machine marks, or scratches. (other models like chrome, painted {to match your bronco} are available but cost more...like $325.00 for the Chrome one, but man it is a piece of ART. The Pulley is painted black, not just any black but almost like a lacquer. When you spin the pulley with your hand you couldn't even feel the bearings inside, and the PA unit is at least 5 pounds heavier than the stock unit. The fit and finish on this product is SHOW TRUCK WORTHY! I can't say enough about it.
PA also sent me in the box a sheet of paper, on the paper was a print out of THAT PARTICULAR ALTERNATOR's output at rpm level, via serial number. spun at idle, minimum output on mine is 93 amps, midrange of 110 amps, three thousand rpms = 135 amps and ...........at 5g = 151 amps!!!! They have higher amp numbers but at RPM's that I will never see. The peak on this unit is just under 195 amps (at like 8g).
I will dig out the paper and post it so ya'll can see. This thing in my opinion is worth its' weight in gold. For those guys out there pushing even more lighting than me, or mega huge stereos, the 165amp unit is awesome, and for the true extremist the 200amp unit is king! A few words of caution on the 200 amp unit. It requires a complete rewire on ALL of your electronics...selenoid, starter, fuse block, etc. It will fry an older stock system AT IDLE!! (the guys at the shop say the 200 amper goes out to like 325 amps at 5,000 rpm... ugh!! enough juice to run a house!)
I am not an expert electrician or anything so I went with a strong, near stock unit that required MINIMUM handiwork with electricity. And so I chose this unit and I have had absolutely no problems.
