1 - 11 of 11 Posts
Sneaky Ba$tard
Sounds like a bad fuel presure regulator to me, or possibly a bad injector. I'd check the FPR first if it was me......Good luck--Fog
I had the same issue just a couple weeks ago. my fuel pressure regulator took a chit and let to much gas get into the motor and got into my oil, I replaced the FPR changed the oil and everything is fine know. I would reccomend testing your fuel pressure it should be around 35psi if you have a working FPR.
The Anti Yam!
timtime said:
Gas is being siphoned back into the motor and filling my oil pan full of raw fuel please help if you can
What year is the truck.
If it is a EFI truck it's the fuel pressure regulator.
But if its an older carb truck its not.
Charlie don't surf..
'92 Ford Bronco XLT
Yeah we need some more info. Anything you've had done to you rig recently.
1 - 11 of 11 Posts
