yo,
Ck Tank Dimensions;
78-79 25.5 Gallon, 31 7/8" x 22 1/4" x 12 3/4"; 33 Gallon, 31 7/8" x 22 1/4" x 15 3/4";
80-83 25.5 Gallon, 31 7/8" x 22 1/4" x 12 3/4";
80-89 33 Gallon w/2" Sending Unit Hole, 31 7/8" x 22 1/4" x 15 3/4";
90-96 33 Gallon w/3 5/8" Sending Unit Hole, 31 7/8" x 22 1/4" x 15 3/4";
Weight, 32 Gal. in 88-96, 31.0 lbs
In case you need to Inspect/R&R sending unit, instead of dropping it, consider; Floor Pan Cut-out - see my site for Links
http://www.broncolinks.com/index.php?index=616
Examples are:
Cut-out Panel Measurements for Fuel Pump/Level Sender Replacement in an 88
Source: by Jem270 at
http://www.supermotors.net/registry/9036/59534
"Each about 8-10" front-to-back and just over 3 ridges wide (as shown), so they'll cover a hole less than 8" long & 3 ridges wide)..."
Source: by Steve83 (Steve, That dirty old truck) at
http://www.supermotors.org/clubs/superford/vehicles/registry/detail.php?id=2742&s=33276#content
Lessons Learned
Source: by digitalbill (Bill Crozier) at
http://fullsizebronco.com/forum/showthread.php?t=152867
Patch Panel, 48in. x 16in. for 80-96 Bronco & F Series; $35.00 as of June 2011
Source: by Jeff's Bronco Graveyard @
http://broncograveyard.com/bronco/i-34094-rear-bed-patch-panel-48in-x-16in-.html
or go to a yard w/portable sawzall / grinder and remove a patch from any up to 96 Bronco or F series.
84-89 Overview & High Pressure Pump Depiction; "...Two electric pumps are used on fuel injected models; a low pressure boost pump mounted in the fuel tank and a high pressure pump mounted on the vehicle frame. The low pressure pump is used to provide pressurized fuel to the inlet of the high pressure pump and helps prevent noise and heating problems. The externally mounted high pressure pump is capable of supplying 15.9 gallons of fuel an hour. System pressure is controlled by a pressure regulator mounted on the engine. The pressure regulator reduces fuel pressure to 39-40 psi (269-276 kPa) under normal operating conditions. At idle or high manifold vacuum condition, fuel pressure is reduced to approximately 30 psi (207 kPa)..."
Source: by Chilton
Fuel Level & Sender Testing in 87-88 Bronco & F Series; When the fuel gauge needle is below the 1/2 to 1/4 tank range the needle will swing all the way above the full mark on the fuel gauge; An erratic fuel gauge needle when the fuel tank is 1/2 to 1/4 full may be caused by excessive wear of the resistive film on the fuel pump sender assembly. The wear occurs during transporting of the vehicles via rail or truck over long distances. The fuel gauge will indicate correctly from a full tank to about 1/2 or 1/4 tank of fuel. When the fuel gauge needle is below the 1/2 to 1/4 tank range the needle will swing all the way above the full mark on the fuel gauge. To correct this, install a new fuel pump sender assembly.
Miesk5 Note, Pre-87 fuel level senders are TOTALLY different from 87-up. Not only do they work over a different range; they work in the opposite direction
Source: by Ford via Steve83 (Steve, That dirty old truck) at
http://www.supermotors.net/registry/media/724794
Tech Tip Guide, General; "...Many times, the Ford fuel pump hanger/sender assemblies are frequently found with extensive corrosion on the cover and on the metal tubes. Over time, the terminals can loosen and cause intermittent loss of continuity. Erratic reading of the fuel sender level is one of the other problems that could occur..."
Source: by spectrapremium.com
Fuel Level & Sender Wiring Diagram in an 89
Source: by SeattleFSB (Seattle FSB) at SuperMotors.net
