1 - 3 of 3 Posts
I'm leaking gas from the top side of the tank in my 84 351w. I'm pretty sure its rusted out. It has a 25 gal now. Will a 33 gal slip right in?
I know on the 78's there was a strap difference ,upper one I believe
not sure on 84
sending unit will also most likely be different
If I'm not mistaken ford started using the 33 gallon in 1985, so unless there is a difference in the rear frame section, the larger 33 should go right in. you MAY need to get a 33 gal skid plate and fill hose though...
1 - 3 of 3 Posts
