no ford trucks
I just installed a tach on saturday and at 60 mph I was running 2300 rpm. I have 33X12.50 BFGs and 15X10. No lift, but can anyone guess at what type of gear I may have, and is that a high rpm? It has a C6 in it and no full time 4X4. Thanks in advance. :rockon
www.easttn4x4.com
Not sure on the gear maybe 4.10. That seems a little on the high side, which is good if you ever plan to put on bigger tires.
Welcome to the jungle
That is correct. 2300 RPM at 60 mph on 33" tires means you're running 3.73 axle gears. In "High" range, the t-case ratio is 1:1, as is the tranny in third gear. Therefore, your axle provide your only gear reduction on the freeway.
60mph=1mpm=5280fpm=63360ipm
63360/(33x3.14)=rpm of tire
rpm of engine (2300)/rpm of tire(611.465)=3.76 <---{Gear ratio} w/ a little rounding error
no ford trucks
I was going to sell the bronco after I got frustrated with it, but with this kind of help, how can I. You guys are great. I look at these forums everyday and try to help when I can. Thanks a lot.
