I am about to regear. I am going with 4.56 gears up front. In the 9" I can't decide between 4.56 or 4.55. Either will work and 4.55 is stil whithin 1% so it works.
I was thinking of going with 4.55 because it will have more teeth contact at any given time therefore making it slightly stronger. The 4.56 has 7 pinion teeth and 32 ring gear teeth. The 4.55 has 9 pinion teeth and 41 ring gear teeth.
The only reason I thought of this was because some of my friends run the 4.55 on drag cars because of the added strength along with after market 9" and with 35 spline axles. I know the Bronco wont be putting out 700-800 ftlbs of torque like there drag cars.:histerica
So what is everyones thoughts on this? Or is the 4.56 strong enough that it wont make a diffrence? Or has anyone blown 4.56 gears and wish they had a little added strength?
opc1:
