GEARS!!, Please read before posting gear ?'s. Updated 11/11/03
Here are some really good equations for determining what gear ratio you may want to concider.
Remember that this is reference only and is based on equasitions from simple math.
Your tire size may be listed as 33/35/37, etc. but the actual measuremnet of the tire could differ once it is mounted on your rim.
Also this write is assuming you have an E4OD, or similar auto tranni.
These are figures that I came up with, to do your own just do:
Circumference of tire divided by the gear ratio you want.
Then compare you answer to the stock forward measurement of 25.5"s and then you will know if it fall over or under.
Stock 29" tire (235/75R15), with 3.55 gears, 90.7" is circumference of tire, thus for every turn of the drive shaft, you go forward 25.5" or so.
33" tire, 3.55 gears = 103.7" circ, forward 29.2", about 15% more than stock
33" tire, 4.10 gears = forward 25.3" basically same as stock
33" tire, 4.56 gears = forward 22.7", about 11% less than stock
35"s with 4.10s = 26.8, 5% over stock roughly.
35" tire, 4.56 gears, 110.0" circ, forward 24.1", about 5% less
37" tire, 4.56 gears, 116.2" circ, forward 25.5", identical to stock (within error)
37" tire, 4.88 gears, forward 23.8", about 9% less than stock.
38.5" tire, 4.56 gears, 121.0" circ, forward 26.5", about 4% more than stock
38.5" tire, 4.88 gears, 121.0" circ, forward 24.8", about 3% less than stock.
FYI, for those who are thinking they can run a 35" tire with 3.55 gears...
35" tire, 3.55 gears, 110.0" circ, forward 31", about 22% more than stock. That means that your motor is working (and your clutch or torque converter) quite a bit harder to move your truck. That's why it dogs so bad.
If it falls "under" your motor does not have to work as hard to turn the tires, but it does it at a higher RPM. This means that as you go more "under" you lose top end. If it's "over" you'll have a higher top end, but less grunt.
Thank you.
