1 - 14 of 14 Posts
green ones make me horny
Well first off I searched but couldnt find the answer.
I know there is a carrier break in the front 44. my question is when i buy the gears do i need an open carrier for 3.92 and up like this here.
http://broncograveyard.com/bronco/i-32022_d44_carrier__case_only_3_93_up_open.htm
or do i want the complete one like this
http://broncograveyard.com/bronco/i-32024_d44_carrier__complete_3_93_up_open.htm
I know i need the install kit and the gears obviouslty but what else should i get while im in there?
I'd also like to know. I would think the first one....
well one is complete and one isnt that is why im asking.
Designated Tranny Killer
you can swap internals over with out any issues. unless you have a limited slip up front now and you buy a open case.
Discussion Starter · #8 ·
it is stock i dont think it has limited slip in front does it? I thought it was just the rear.
Look at the front axle ID tag to see if its L/S. If it is it will say; 3L55 = 3.55 ratio limted slip. If its open it reads: 3 55 = 3.55 ratio open carrier. The ID tag will be held on by one or two of the bolts in the center section(pumpkin).
And they do not make think reverse spiral gears.
There are 2 carriers, series 3 and series 4. Series 3 is for gear ratios up to 3.89. series 4 is for 3.92 gear ratios and higher.
Examples for series 3 carriers= 3.08,3.25,3.55.3.73,3.89
Examples for series 4 carriers= 4.09,4.23,4.56,4.88,5.13
I hope this answears your questions.
was your rear axle LS?
as said before, check the tag.
Discussion Starter · #12 ·
you talking the tag on the door
the tag thats bolted to the diff with the bolts on the TTB arm.
Discussion Starter · #14 ·
its raining so i will look tomorrow
1 - 14 of 14 Posts
