That being said, about a 4.88 for close to stock feel with a 40" tire. You can go higher and lower form there, I suggest you check that tread out. There's a lot of good info.37" tire, 4.56 gears, 116.2" circ, forward 25.5", identical to stock (within error)
37" tire, 4.88 gears, forward 23.8", about 9% less than stock.
I stuck with 5.13's because 5.38's for a 14 bolt were not sold then, and even now the only one who has them is yukon. :uke:I'm runnin 5.38s with 42s
i went with 5.38 because i couldn't go any lower in the high pinion D60, and whats wrong with yukon?I stuck with 5.13's because 5.38's for a 14 bolt were not sold then, and even now the only one who has them is yukon. :uke:
Stock ratio is 3:55's. I went with 4:56's and 38's to keep near stock RPM's. (2700 RPM's @ 65 MPH) I would also do the same with 37's. If your going 40's then I would run 4:88's.![]()
yep.....weekend warrior...to the woods, pull the boat on ocassion.
