1 - 8 of 8 Posts
problem:
hit brakes and pulls to the left, sometimes goes cluck
so far i checked:
brakes look good
all moving parts are solid
bushings look good
replace the cal. pins
blead the brakes
so what em i missing
also does taking off front sway bar help after putting on 32x11.5. my dad told me after a certain size sway bar can become a hazerd
my 95 is doing that now, but to the right, but it is cause one of the caliper bolts that holds the caliper on is striped on the bracket side, also could be warped rotors.
o[|||]o
You may have a chicken lodged in your left front wheel. :brownbag
I have run 33s with no sway bar and it was/is perfectly driveable.
Actually, the bigger you go, the better a sway-bar is.
Mine makes the same "tick-un" noise. Sounds like it's coming from the master cylinder or something in that vicinity. I have no idea whats causing it and would like to know. Will it do it with the truck dead? Mine does at about 1/3 pedal without the truck working.
As far as pulling ot the left goes, how are your tie-rods, ect. I've had messed up tierods contribute to pulling; that is if all the other stuff does indead check out. It's probably just one side is more worn than the other . . .
found the chicken:thumbup belt screamed last year, removed the cat. poooor kittie, had to tell the neighbors that stripes is streeeeched
ra looks good, unbolted from the center link. nice and solid
rotors new oct05
only makes noise under hard braking.
the good news is. when it does brake, it will be the thing that broke:toothless
1clean5.8 said:
Did you check your RA bushings
:stupid :stupid
This is exactly where I would be looking first.
1 - 8 of 8 Posts
