broncoorboat said:
what are conidered basic parts?
If you search I know that there was a thread with a list of parts and tools to take when wheelin.
Everyones list will be a little different but basic should include at least:
Tow strap (no metal hooks on it)
Ujoints for front and rear
oil filter
fluids
serp or v belts
fuses
full size spare tire
a few extra lug nuts/studs
an empty sealable container for fluid changes
This list is no where near complete. I carry alot more stuff than this. But it's a pretty good idea of what you should have for parts. We went out last time and needed a starter on the trail. We had one time before that someone broke their ball joints we had them, someone also needed a v-belt pulley we had one it needed to be modified but it worked, busted ujoints had them, broken alternator had one, I'd say so far the only thing we've busted that we did'nt have with us was a gas tank. Oh and a radius arm(bent). It sucks getting stuck on the trail trying to fix somebodies rig who doesn't have parts. Or always giving out parts because people figure that so and so will have it. We want you to come out and wheel we just want you to be prepared. You don't need to run out and buy all new spare parts. The next time you change the belt on the truck save the old one if you're at the junk yard pick up some extra parts. Buy the cheap wally world fluids that come in the gallon containers to keep in the truck and a couple of cheap filters. Remember the stuff just needs to get you home safely, then you can spend the money to repair it correctly or permanently.
Remember SEARCH there are multiple threads with lists for parts, tools, etc that can be taken when offroading. Usually the more you wheel the more parts you bring. Because eventually the more you wheel the more you break.
