:cry
ok i honed out and cross hatched the block (after buying the rebuild kit stock bore).
and when i went to use the bore gauge to check to make sure i did not tapper the cylinders to much, i had to add to the gauge. so i took a piston out from the kit and slid it into the cylinder, :cry ,:cry ,:cry ,:banghead ,:banghead ,:cry,:cry, :cry .... thats when i found out i got too far ahead of my self,, i have to much and i meen way too much side wall clearance. i can take one of my pistons for my 1979 block, (.060 over size) and slide into the cylinder and have about .003 side wall clearance, so basicaly what i am asking and thinking is this, if my engine was already bored out when i bought it, would that have helped (along with #24 injectors) with the melt down and burning holes in the piston? and if not then can i run a .060 over sive bore with a stock ecm? sorry if this is in wrong forum please feel free to move if need be:drinkbud
