Shock boots Yes or No?
  • Yes I use the shock boots
    Votes: 50 55.6%
  • No I do not use shock boots
    Votes: 40 44.4%
1 - 20 of 32 Posts
Can't wait to get them installed. The Bronco has been crying for new shocks for over 10k miles. Anyway they came with boots installed on them already. I didn't think they would and wasn't planning on using any boots. My experience tells me that with boots there tends to be a small pool of mud/water/sand that can build up over time at the bottom of the boot, which is right where the piston of the shock enters the body. Even in a relatively dry climate like Colorado I still get some moisture. Anyway what do you guys think? Use the boots and clean them out every once in a while. Or run no boots and expose the whole piston to the elements all the time? Both have their drawbacks. What would you do?
I run boots but mine have holes in the bottom so that water and mud can run out.
It's BTW Not AKA!
Mine never stay on right anyway.
My experience, Zip Ties Suck! :goodfinge I may run no boots in the future but I worry about mud, crud, water and beer getting into my reservoir.
Right I am running boots on my rs5000's and as I said before, Zip Ties Suck!
D
yes
D
I'm mainly worried about the road salt in the winter
the mag cloride in the winter here in CO will just build up in them (evan with holes). I'd say no we live in a vary dry area and rust will not be a problem. I'm sure you know all this you have been here for a time. The crap they use on our roads in the winter is our worst culprit for carosion. NO BOOTS.
1994 Bronco 351W, E4OD 6" Superlift, 35 BFG KM3 4.56 gears Detroit
Every rig i have ever worked on that had shock boots had trashed leaky seals because they held in mud water and debris. I run no shock boots and have never had any problems. I tried running them once but they would never stay on right anyway so i tiik them off and never looked back.
1 - 20 of 32 Posts
