1 - 20 of 26 Posts
huh
1995 Bronco, Slightly Modified
Gotta thank crazed for the stock pitman arm he sent me.. It worked like a charm.. My drag link and trac bar are almost exactly the same now.. ive got the clearance i needed for the ram, etc.. Crazed was nice enough to give me the pitman arm for free and wouldnt even charge me for shipping.. I guess what goes around does come back around.. It was pretty cool.. :beer
thanks again.. :drinkbud
side note... the 7th time pulling off and taking apart the steering gearbox was the charm.. its not leaking anymore, its working and its tight.. :rockon one step closer.. one step closer.. :chili:
Are the hydraulic lines temporarily right out in front there, or is that how you are planning on running it? I moved mine and ran them through the oil filter hole thing in the crossmember and it seemed to get them out of the way pretty good, but its prolly not too safe having them that exposed, i learned from experience. Also, I do believe you are the only other person I know who has given up a dropped pitman arm for a stock one...
huh
Discussion Starter · #12 ·
thats temp till i drive it around the block and see if the box doesnt leak.. after the first time having to cut my zip tie masterpiece off i figured id wait.. so yeah,,.. its temp..
i needed to.... if i would have stayed as high as i was before the coilovers i could have left it...
scrounger extrordinaire
I gotta lose the dropped to get the D60 under there. but i kept the stock arm for some reason. looking good man, cant wait.
I run a stocker too.
Master Bater
thats great. I shipped a bunch of stuff to my ex in Fla. at the same time, and it appears that they sent it to her instead. She has yet to pick any of it up, so I cant be sure, but I will have her tell them to send it back to you if you still want it. That really pisses me off. In fact, i am going to make them do it just to screw with them
actually, check that, for some reason it is in memphis and has been for a week. im on the phone with them, you should be getting it soon. not that you need it anymore I guess
1 - 20 of 26 Posts
