1 - 8 of 8 Posts
Hello everyone I recently took apart my gauge cluster and while under my dash saw a plug unplugged what had a y/w wire to it. My sending unit is also not reading and the wiring is supposed to be that color. I can't find where it goes. If anyone can look and take a picture it would be appreciated, I can't seem to find the other side. 96 bronco xlt 5.8L
179056
Am I seeing things, or do you have a black connector above it (below the right leg of the arrow, as oriented in the pic) with all the wires clipped? Looks like there are a bunch of old, add-on wire splices by it, also, that might be branching off the wire bundle the arrow points to.
Dunno if that helps, but I would start there.
Yeah that's there lol. I'm thinking it used to be an aftermarket alarm system. It's different style plug than I could find and everything else on the truck works. I'm going to look at a friend's 93 today so hopefully I'll get some answers there.
Yo Ace,
From 1996 EVTM
C250 Instrument Cluster, Behind top LH side of I/P, on instrument cluster (A6) Terminal: 14 Color: BR
●C251 Instrument Cluster, Behind top LH side of I/P, on instrument cluster (A 9) Terminals: 14 Color: GRAY
Reactions: ACE96
Hello everyone I recently took apart my gauge cluster and while under my dash saw a plug unplugged what had a y/w wire to it. My sending unit is also not reading and the wiring is supposed to be that color. I can't find where it goes. If anyone can look and take a picture it would be appreciated, I can't seem to find the other side. 96 bronco xlt 5.8L View attachment 179056
Are you pointing to the 2 pin plug that's taped to the harness? If so, that's for programming new keyless entry remotes. Your RKE box is directly above it.
Yeah I realized it earlier this morning. Should have seen it sooner because I have done that before lol. Well seems like I'm off to go get a sending unit and drop the tank.
good luck! No one stocks them locally. I think JBG and LMC are the only ones that carry them for the 92+ now. You might want to disconnect the wiring first and see if the gauge responds. You can test it without dropping the tank.
Discussion Starter · #8 ·
Yeah that's true from what I've found! Recently my fuel pump started making the high pitch whining of death after some Lucas fuel system cleaner which I thought might happen. Pretty sure it's the original pump after 260k miles so I've already pulled one from a junkyard that I'm going to put in this week. (I'm a broke highschool student) Thanks for the help!
1 - 8 of 8 Posts
