1 - 12 of 12 Posts
Hi folks...I'll start this by saying I ran a search on the forums to try and find the answer...I have found nothing that describes what my old girl is doing. I have Avery limited mechanical knowledge but I can use tools. She's making a groaning/rubbing sound in low speed turns. It almost feels and sounds like a tire rubbing but the tires are stock size with no lift. It only really does it when I'm starting off from a stop but not any other time. Any ideas before I take it to a mechanic and pay out the nose for them to tell me the problem?
The power steering pump can make a lot of groaning noises when turning, particularly from a stop. It will sound somewhat like a groaning or a whistling noise.
Have you checked the power steering fluid level? If it's low that can make a really bad groaning sound too.
I dunno that may not be what you're talking about sound wise but just my first thought.
I replaced the power steering pump 2 days ago...it was out completely. It almost seems like it's coming from the rear end
Well, the tires in the back don't turn so that's not going to be the issue (tires turning).
But you could get a grind or a whine from the back of the rear end is going. You could also get a thump thump thump thump thump type sound when you're driving that increases in speed as you do.
Slipping/worn out limited slip clutches(if your truck is equipped) can make a similar sound when turning, especially turning right.
You may want to remove your differential cover and check things out, post pictures of the oil.
I'm almost betting just looking at the dif that it's never been opened...in 225k miles
I would probably take the cover off and take a look inside.
Even if the diff isn't your problem it wouldn't hurt to change the lube. If it hasn't been opened up for 225k miles I guarantee you the LS clutches are long gone
imdabes
Lift the front end and try to wiggle the tires side to side and front to back. Could be a ball joint, sounds like a tie rod end to me.
Thanks for the advice folks...I'll be looking at it this weekend...hope it's not too big of a job whatever it turns out to be
imdabes
Also make sure to grease everything. Greasing all the zerks you can find will get rid of lots if weird noises.
Discussion Starter #12
Well folks...the rear dif wins...lots of metal shavings and a missing tooth or two...now the question is repair it or replace with the beginnings of my trail rig set up...that I still don't have figured out
1 - 12 of 12 Posts
