At the junk yard today, I found a 1997 Ford Explorer, 5.0L V8. The VIN shows the Explorer's production date as Jan/07. While I'm expecting to learn that the heads are GT40 (based on the early production date), I don't yet know if the heads are GT40 or GT40P's; and, I don't know if the heads have the crossover ports.
This JY find catches me a little off guard because I'm not well enough studied on the subject to make an informed buying decision regarding what parts to purchase. So I'll just ask for your collective opinion.
I currently run a stock 1995 OBD1 5.8L. I want to retain emissions functionality. I don't want to see CEL's. I don't want to spend more money than is necessary on exotic parts. I'm looking for the most bang for a reasonable buck. I daily drive my truck, 90% in town, 10% easy off road. I enjoy long highway road trips, and like the stock gas mileage which is always 15 mpg plus. I have a light throttle foot and my normal RPM range is 1500 to 2200. I turn 1650 rpm at 55 mph.
Here are my current resources:
I recently bought a crate remanufactured .030 over long block 5.8 for my Bronco.
I can always use the reworked stock 5.8 heads as book ends...now that I found the GTs
I have a complete (disassembled) 1993 5.0 engine, including upper and lower intake. I've read that the 5.0 intake is an improvement over the 5.8; and, this 5.0 intake would retain stock emissions component locations and linkages.
Now that I've found this 1997 Explorer GT40 motor, complete, I have questions.
Maybe someone could just spell out their opinion of the best torque improving truck setup based on what I've listed so far.
Specifically, my questions relate to whether I should purchase of the entire '97 Explorer motor, including the ECM and harness; or, just the engine; or, just the heads and intake; or, just the heads. If not the whole engine, what about the cam along with the heads and the intake?
BTW, the JY quoted me 69.00 for the pair of GT40 heads and 42.00 for the intake. While I didn't get a quote on the whole engine, but I'm guessing the entire package could get expensive.
Could someone comment on the merit of using the Explorer block, including internals, as opposed to using the block I just bought. I'm willing to buy whatever cam I need in order to build torque and take advantage of the other parts I've listed; and, I'm willing to go OBDII and source an appropriate ECM if the Explore ECM isn't up to snuff.
Thanks.
Thanks.
