1 - 20 of 26 Posts
just curios what psi you run in your rubber?
i run with 35 also
Designated Tranny Killer
35-40 on road, 20-25 in the mud and 15-20 on the sand
Satyr of the Midwest
40psig, front and rear. Someone on FSB has a picture of a FSB certification sticker with this exact pressure on it for 31x10.5-15's.
Sayulita Layta!
I run 35-40 psi on the road. I have never aired them down offroad, there isn't enough clearance under the axles to air down.
1982 Bronco XLT Lariat, 351W, C6; 1989 Bronco XLT, 302, AOD
I run 35 psi in mine all the time. I don't do any off-roading, strictly highway.
Tony
I just pull my rubber on, insert, and pump up manually :goodfinge
call me crazy but i run 40 in the rear and 35 in the front, i get better gas mileage
Discussion Starter #13
The tire will tell you
I think he meant that on more then one level. If you've got an appropriate tire for the wheel, running it at max psi will leave you with probably the best tread life...
Not only that, but visually looking at or measuring the tread in the center versus the edges will let you know after a few thousand miles whether or not you need to up or down the pressure. If you're chewing up tread in the center, you should probably drop the pressure down for more even wear, and vice versa.
I don't have a picture, but I have that tire size and the actual factory PSI on the door sticker is 32 psi.
I'm stuck :)
i run 40 runs a little rougher but seems to get a little better mileage
35 psi. I never air down for wheeling either. Running a slightly lower PSI really helps with comfort. Truck doesn't rattle as much.
1 - 20 of 26 Posts
