1 - 4 of 4 Posts
I have started a d60 swap and I'm doing everything the way a 90 F-350 mounts. My question is are there any existing holes that the new rear spring hanger would use? I'm trying to bolt them up today and this information would be greatly appreciated.
Cody
I keep looking at that but what I want to know. Is there any existing holes in the frame that I can use or for referance. I'm just trying to bolt them up now and ran into a wall. If I can get this answered then I can get back to work.
Cody
Everyones will be slightly different so that wouldnt work to well. The body mount is in the way and depending on how you work around that it will make a difference...also it depends on where the front hangers are hung too...some move the axle forward 2 inches....I centered mine in the middle of the wheel cut out on the fender...just find something that is the same on both sides to measuer from to get it straight...and measure more then once to make sure your not off...wouldnt want the axle crooked...
1 - 4 of 4 Posts
