1 - 9 of 9 Posts
Engineer
Well I need a new stub shaft, new radius arm bushing on the drivers side and I had to install my 2.5" coil spacers.
So we needed to fix this
With parts from this
Removed the TTB from the parts truck
My new spare D44 third member, just in case I wreck another one
Working on replacing the Radius arm bushing, Yeah it takes 3 ratchet straps and a come along
Pulling out the broken shaft
The carnage
Yeah that's a 4 car garage
WHERE IS YOUR GLASSES?
Engineer
I'm wearing them in all the pics, an no they arent safety glasses
I have washed my arms and hands 10 times and they are still dirty. That truck and garage and parts truck are dirty as can be.
Engineer
Marauder said:
Dont wash your truck or anything to work on it, heaven forbid someone thinks your just a poser :goodfinge
It keeps my stuff safe inside the garage, people cant see in the windows
Wash the truck before you work on it, you'll come out cleaner in the end.
Also, you're willing to grind rivets to pull the TTB, but not to pull the RA bracket? I don't understand that at all. RA bushings are *so* much simpler when you just drop the bracket.
we didnt grind any rivets. we ground through a u-bolt it took 2 minutes. There is 4 or so rivets to grind and knock out. Our come-along didnt actually take that long.
Engineer
Discussion Starter · #9 ·
We used the grinder on the u-bolts for about 4 seconds. The radius arm wasnt too bad since we had to remove the shocks and coil anyway
1 - 9 of 9 Posts
