yo,
For testing, wiring diagrams, etc...
see my site for;
Intake Air Temp (IAT); (Air Charge Temperature [ACT] prior to 1992)
http://www.broncolinks.com/index.php?index=398
Engine Coolant Temperature (ECT) Sensor
http://www.broncolinks.com/index.php?index=918
-- more Wiring Diagrams in an 86 & Ford truck
Source: by Agnem (The Moosestang) at webshots.com
These are diff ro read due to size for non- members of webshots.com, so consider registering there.
Wiring Diagrams (Partial, Bronco similar) for F 150 in
86, 89, 91 & 95; EEC, Start/Ignition, EFI/Fuel System, Emissions, E4OD, AOD/C6 (+ clutch interlock switch), etc. from Electrical & Vacuum Troubleshooting Manual (EVTM) & MAP, TPS, ECT, ACT, KS), Start/Ignition, Fuel System, Emissions
Source: by Ford via Ryan M (Fireguy50) at
http://fordfuelinjection.com/?p=36
1986 F-150 5.0L pg60
1986 F-150 5.0L pg61
1986 F-150 5.0L pg62
1986 F-150 Ignition pg29
1986 F-150 Fuel System pg103
Compare to Moosetang's for any differences between Bronco & F series.
Look Codes up in my broncolinks.com site using the new Search function if in a hurry today
for example;
DTC 31 or 32 Both KOEO & KOER; " EVP sensor out of range EGR is sticking or EVP is bad, see my site's, Emission section; EGR for basic tests, w/hand vac pump, etc." @
http://www.broncolinks.com/index.php?index=414
Source: by miesk5
DTC 31 "... This code could be caused by several different factors. If the pintle position sensor (Ford calls it the EVP sensor) is shorted or open, you could have a code set. If the EGR valve becomes carboned up and does not seat fully, the EVP sensor gives a high reading and a code is set. If the diaphragm of the EGR valve is bad, then it, too, is flagged..." by Harry G at asashop.org
DTC 31 EGR Valve Position (EVP) Sensor; "...On-Demand codes have been coming up and the voltage on the EVP sensor (EGR valve position sensor that is mounted to the EGR valve) is reading correctly on Fords. The problem seems to be that sometimes the wrong sensors are being installed and are therefore sending the improper voltage signals to the powertrain control module. Ford uses two different EVP sensors: a black and a white (or gray). And both will send a different voltage in the same position. At rest, the black sensor will read .75 to .95 volts and the white (or gray) will read .35 to .45 volts..." read more... by Dan J at asashop.org
