1 - 12 of 12 Posts
green ones make me horny
Hey got a quick one for you guys. This morning the bronco would just keep spinning and would start. I held my foot down on the gas and it started. I didnt trouble shoot anything yet cause i am dropping the new motor in it tomorrow just wondering what could cause that?
Thanks
ken
Check for codes..weak compression..Theres a hundred diffrent things that COULD cause it..
its not throwing any codes. i laready checked
Gacknar said:
You ran the test?
yes and it gave me the 111 system pass
its almost like an old carburated motor thats not getting enough fuel.
Satyr of the Midwest
If you put the pedal to the floor, the EEC goes into "Clear-flood mode," which is almost exactly what happens in a carbureted setup when you flood it and do the same to clear the cylinders of excess fuel. The injectors are cut off; their pulse widths go to zero.
Therefore, if you were sitting there, cranking away for a while and then put your foot to the floor, and then it started, you more than likely had a flooded engine. You should NEVER have to touch the gas pedal to start a fuel injected engine. Anyone remember when Ford coined "touchless starting?"
Check your TPS and ECT, make sure they're playing nice.
well i am putting a new engine in tommorow so all that shit is going to be replaced. thanks for the information i do not floor it to start it i just lightly tap the gas and it starts. it on.y does it if i dont let the fuel pump prime.
Ken
checked codes again when i got to work adn got a 116 coolant temp sensor high voltage. that is all
Lick my balls
Ken
I thought you were getting a long block. If that's the case, you will be using all the sensors you have now. Unless of course you plan on spending another grand. I take it your back is better...good.
Discussion Starter #12
i do have a long block. my back is feeling good enough to put the engine in. and i am going to test all the sensors and see what i need to get.
ken
1 - 12 of 12 Posts
