Yo in4thewin24,
As Clarko advised,
Swap, between 78-79, 80-91, 92-96; "...The only groups that you can interchange are 80-96 with some modifications. 80-83 sliding side windows directly fit 80-96 shells.
78-91 Broncos use 4 short bolts (8mm head, 6x1.00x40mm) on each bedrail & 5 long bolts (8mm head, 6x1.00x70mm) in the upper sections. All bolts thread into U-nuts, except the 2 upper corners & the 2 rear corners which use captive nut plates. The bedrail bolts each use a clip stamped "L" or "R", but the rearmost bolts use the opposite clip. The clips for the B-pillar bolts are not marked, but the smaller tab goes down.
92-96 Broncos use 5 short bolts (tamper T-40 head, 8x1.25x30mm) on each bedrail & 5 long bolts (tamper T-40 head, 8x1.25x60mm) in the upper sections. All bolts thread into U-nuts, except the 2 upper corners & the 4 rear corners which use captive nut plates. The bedrail bolts each use a clip stamped "L" or "R", except the rearmost bolts. The clips for the B-pillar bolts are not marked, but the smaller tab goes down. There are also nut plates in 4 of the camper shell bolt holes: the 2 rearmost, and the 2 outboard at the top of the cab. They're just a heavy plate (1/4"?) with a threaded hole...."; miesk5 NOTE; 92-96 have rear seat shoulder belt mounting points & 3rd brake lights
