i got kind of a dumb question,would a grade9 bolt be the same a an f-911?
the fastener co.i deal with carries grade 9 they dont have f-911.
I believe the f-911 and grade 9 are similar in properties, but the f-911 are a "proprietary blend" and may have a slightly higher values than generic brands. Start a thread at www.offroadfabnet.com and ask the same question. You should be able to get some qualified response there.
there are also some threads on rdc about bolts. i talked to a bolt guy that has been racing since before i was born and he swears by gr8 and would never run f911 because they break.
i was thinking grade 9 would be ok, the bolt is 3/4 x 22. it is a spindle thru bolt on a toyota race truck.so i just wanted to see what your responses were.
i have heard that the f911 break also from others, i'll check out the other threads too
