My 79 Bronco will run in the "M" range for a while and then go past the "L" and hover there for a little and then shoot back to the "R". In the NORMAL. I know it is normal to run in the normal range, but why the fluxuation? Is this a sign of a bad thermostat? Also, if you have a plugged catalytic converter, will this make the engine run hot? Thanks. Oh, it is a 351M with a 4bbl carb with no egr or air pump, dont have to have emissions for this old of a vehicle. It does still have a old cat on it though. Thanks for all your help. :shocked :slap :chili:
